by iceblock » Sat Jun 16, 2012 12:54 am
Thanks for the reply Chompsticks, I'll check that out. Yes, you know when you push the ignition switch, if you listen you will hear the steering lock module in the steering column release. Well when that module quits working, you hear nothing. You push the ignition and nothing happens because the electronic connection is disrupted and the whole module has to be replaced just so the car will start. It's a faulty part that just quits working. The remotes have to be reprogrammed as well after the module is replaced and if it wasn't under warranty can be aprox. a $400 to $500 job.
