matttail »
https://forums.nicoclub.com/matttail-u50105.html
Wed May 28, 2008 10:10 am
This isn't a versa issue. It's a standard property of static electricity. You rub up against a surface like cloth, or a balloon to your hair and you generate static electricity. Sometimes surfaces can be treated to help cut down on the amount of electricity (think dryer sheets).
Simple solution that will work every time: Touch metal before you start moving to get out of the seat and keep touching it till you're safely out of the car. This way the electricity is discharged as it's being built up and you never feel a thing. You can also hold your key and use that to discharge, but you can still feel it a little (and might not be great for the electronics in your key).
