My car's electrical system seems to be a bit out of whack. I wanted to see if anyone has experienced similar issues or has any advice for trying to figure out what the problem is.
Sequence of events:
- May 19: The car started fine in the morning but couldn't even manage to unlock itself in the afternoon. My (four month old) battery was dead so I replaced it under warranty and went home from work.
- May 20: Car started in the morning with the "Service Engine Soon" light on; codes P0463 and P2103 were stored. Later that afternoon, the car would not start. After several phone calls to my mechanic and a couple of local dealers, I cleared the codes on their advice. The car then started right up and everything seemed fine.
- June 10: Car did not start on the first try in the morning. It started normally on the second try with codes U1000 and P2103 so I drove to work. Around noon, a coworker sent me a text message saying that my car's parking lights were flashing. I went to the car and the start button would not respond to being pressed. I pulled codes U1000 and P0463 (the P2103 code from earlier in the day was magically gone). I momentarily disconnected the battery and the start button started working normally again and the lights stopped flashing. I left the car with the battery disconnected so the battery wouldn't get drained.
Code P2103: Throttle Control Motor Relay Circuit Short
Code U1000: Controller Area Network Communication Line - Signal Malfunction
Battery generally somewhere between 13.4 and 14.2 volts.
I'm assuming all of that means that there's a short somewhere. Any suggestions for figuring out where? I'm pretty handy with small DIY electronics but the sheer scale of a car's electrical system baffles me. I rather check here before I start poking around with a multimeter. Any and all advice is appreciated!
