cimarookie »
https://forums.nicoclub.com/cimarookie-u241129.html
Tue Sep 16, 2014 2:06 pm
Hi guys! thanks for the replies! it turns out that my flooring the gas peddle while starting the car was what caused the issue. Doing that temporarily cut off the fuel to the engine, but would eventually cut back on if i cranked it long enough. gurgling sound would happen when I pressed on the gas a third of a way down. I was pressing on the gas in an attempt to decrease the start time on the car (less cranks).
So, my cars starts every time now with my just holding the key in the start position till the engine starts (5-6 cranks- not sure if i'm using the proper term). I'd let to bring it down to 3 cranks on morning starts and 2 cranks on recently used starts. I'll be changing the spark plugs and air filter soon and doing a direct air pressured fuel injector cleaning done to see what that gets me. i've already changed the fuel filter, oil filter and oil.
If the air filter and spark plugs and air pressured fuel injector doesn't get me the fast start up that I'm looking for, i'll look to getting a battery with higher cranking power.
is there anything else I should try?
