Serdriver »
https://forums.nicoclub.com/serdriver-u291991.html
Tue Jun 09, 2020 8:11 am
I just tackled this job over the weekend. As everyone has stated, yes it's quite difficult and you will spend a lot of time cursing underneath the truck because you can see everything (nuts, bolts, wiring), it's just trying to figure out how to reach it all is the problem. But it's doable! 4WD driveshaft def makes it harder than 2WD.
I went to a local Pick-n-Pull and pulled a starter from a junked Pathfinder for $27 plus $7 for core, and luckily this one had the subframe removed so the engine was hanging down and the starter was easily removable. The unit I removed had Mitsubishi emblems on it, but no Nissan tags, so I'm thinking it was replaced. My truck's starter had both the Mitsubishi and Nissan tags on them, so I thinks it's original. FYI, my truck just turned 146k, and no idea on junkyard truck.
One thing I realized is that the nuts on my truck were a 12mm and 13mm, and the "new" junkyard unit, both nuts were 12mm. I could not get a socket in there, so I had to make do with a 12mm closed ratcheting wrench. The bolt that hold the starter in place can be accessed with a short 14mm socket, although because there is so little room to go back and forth, I used a 14mm socket on a 1/2 in drive to get more leverage/power. Just come prepared with boht 12 and 13mm closed-end wrenches and 14 sockets and you'll be good to go (and 10mm to disconnect the battery!!)
Another sticking point: there's a metal gasket between the transmission and starter, and as you maneuver the starter back into position, it's a PIA to keep it aligned. I probably spent a good 20 minutes fiddling with it before I got it right. Be patient and you will get it. Also, make sure to connect the circular ground points (I think) to the bolts as you put them back in, as I forgot to and had to retake out the bolt and reinstall with the proper connection.
