My starter took a dump the other day and after spending time with the FSM (worthless), on Nico, Q45.org and Google, I undertook one of the biggest pain's in the asses to date with My Baby...
God bless you Drake57... You make it sound almost routine and mundane… I found this to be tedium to the umpteenth degree.
Disconnected battery, two jack-stands on the garage floor, dropped the front stabilizer bar, removed the heat shield and disconnected the connector. I did not want to mess with the power steering line.
Then trying with the tools I had for about an hour trying to bust 2 lousy bolts.… Went to Harbor Freight. My ratchets were too long or too big, open ends too big for bottom bolt, etc… Combination chaos… Bolts were frozen, used penetrating oil. It also took a while for me to get the “setup” right. I don’t claim to be a genius mechanic…
Purchased a 3/8” 4 pc wobble ext set, 3/8” stubby ratchet and an extra u-joint. Got the upper bolt loose by taking a 14mm 3/8” socket to a u-joint to a short ext to another u-joint (both u-joints had duct tape on the “loosely”) to 2 long ext (about 14” in total), then to a 1/2" adaptor/ratchet.
I went up right behind the cross-member near the opposite side of tension rod bolt area and then tilted toward the bolt. Maybe not the prettiest way to get torque on the TOP bolt, but it broke the thing loose.
I did not experience “finger-tight” extraction, saw that somewhere... Used a 3/8” stubby ratchet with a short (2 or 2 ½”) ext to finish extracting. Last maybe 5-8 threads, finger-tight.
EDIT: When I put it back up th next day to check it out and re-torque the bolts, I found a much better path to the top bolt... Sorry JeffTepper, it is very do-able
Bottom bolt is a real pleasure… Some dumbass engineer with tiny hands and fingers should die… Anyway, after trying a variety of unsuccessful setups, I got the BOTTOM bolt loose with the 14mm to a u-joint, to another u-joint to a short ext to a flexible ratchet. Yes, 2 u-joints back to back… I forgot the 2" ext for the pic to a 3/8" flexible.
I’m sure someone thinks I’m nuts, but it is what it is and it worked.
It was a pain to finish bottom with socket-ratchet, so slipped on a 14mm closed ended wrench-ratchet. You cannot get your fingers on it to loosen, don’t waste your time, mine was far too tight anyway. After what seems to be a 1 or 2 click ratchet stroke x 100, it will get to “finger-tight”.
Worked the starter around, twisted, removed power lead to rear of unit, tilt rear up twist counterclockwise a bit and pull out.
Now for some more fun… Getting the new one in… While wiggling new starter around, line-up and finger-tight top and bottom bolts in about 6 or so turns, bottom bolt is a b****. Make sure you jack that thing in flush, and then reverse above.
I’m a rookie mechanic… Took me 4-5 hours, from beginning to end, including a trip to store, a couple phone calls and some quick grub. When I have to do it next time… 1-1.5 hours.
After viewing these posts for these past years… I’m sure there will be a couple Know-It-All’s out there saying I shouldn’t have done this or that. Too Bad!
Maybe if some of these “hot-shots” would post these types of procedures, this site might become more valuable to its members. I was stunned to find so little information on this common repair. Thank God it’s over…
Till next time anyway!
