start signal wire?
tintdude69
Car: 90 Sr20 hatch..
ever since my swap my cars been hard to start when its cold. its not hard at all when its warmed up though. i had my datascan hooked up to the consult and when i start it , its not showing the start signal. so i hooked it up on a ka and it shows the signal when he starts it. my question is, wheres the wire for that. i know its pin 43 on the ecu. from what i find its the orange wire on the dash harness it or does someone have a pic of which it is?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
it's a pin on the ecu that you have to send an extra 12vdc signal to . like pin 56 or something like that. it's been covered plenty of times on this forum. try to search for cold start!
tintdude69
i searched and have been for months. nothing for signal, start, cold start nothing. but pin 43 shows 12 v when starting and 0 any other time so i guess ill just tap the ignition wire that only puts out power when starting and tap it into the ecu
chockrl
Car: Z32 TT, S13 RB20DET
On the S13 it is on the connector under the dash near the ecm and glove box, orange wire. Goes to the P connector, near the ecm and fuel relays, the connector is labeled P in the R32 factory service manual. I think the FSM shows it as a B/Y wire but mine was a Y/L (yellow/blue) wire.
From my response to these previous posts:zerothread?id=225851http://forums.nicoc ... ?id=202681
Not sure why your search wasn't bringing up those threads...
tintdude69
i appreciate it. thanks for responding without flaming
