Peeps »
https://forums.nicoclub.com/peeps-u242385.html
Mon Nov 10, 2014 9:08 pm
Thanks for the suggestions AWGD8. I just bought the car a few months back. It has 47,000 miles on it. I also had a major problem with the steering column, and had the entire upper steering column replaced. When this work was done the battery was unhooked, resetting the ECU. I also followed the directions in the service manual to do the throttle pedal release & idle air learning. This seemed to help for a short while immediately after, but the problems were back the next time I drove the car.
I did have the experience of the mileage range readout dropping rapidly on a low tank. It actually went from 21 miles to blinking lines(zero) in about 3 miles. I have had multiple mechanics look at it and none found any loose vacuum hoses. Based on everything I have read, my limited knowledge, and suggestions from others I have decided to go ahead and have the fuel pump replaced. I know for a fact it was not replaced under warranty, and so it is very likely the issue, or at least one of the issues. Should have that done tomorrow, and will report back once it's done.
