Yup will be a pretty easy bolt on build but remember you will need things like exhaust, downpipe, ECU, and need to get the block drilled for the oil return. Side note dont really trust JGY but thats just me heard quite a few nightmare stories about them. Id say save up and just do your NA build if thats what your plans are. Although I will bring up that Ive never heard of an NA SR motor (VE or not) going anything much over 230 crank HP. If it were me Id say screw NA and just turbo with a T28 at about 14psi and it will put you around 270-280 ish whp it will be cheaper and easier and more rewarding in the long run. Another note you will be fine on stock internals (rods, crank, valve train) all the way up to 400 HP on a SR anyways so no worries there. Just my 2 cents take it for what its worth lolpoweredbyNismo wrote:so im looking to upgrade my SR20VE so i can have at least some fun while im collecting parts for my fully built 260HP NA SR20VE goal.. and i saw the JGY turbo kit for SR20DE for $1500 :O which is perfect to run say... 240ish to wheels on stock internals? so im wondering if the same kit would bolt up to the VE.. kinda like Honda B20B Non-VTEC parts bolt up to B18Cs, B16Bs (etc.)
any input is appreciated.
