RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Wed Aug 10, 2005 6:33 pm
Why not buy a DET and install it yourself? It drops straight in and everything plugs up except EGR, since there isnt any on the DET. Roughly 1700 plus shipping for motor, 3-400 for clutch, 150 for downpipe, custom exhaust 2.5 or 3", couple gauges, motor mount inserts, oil, good tranny fluid, belts, new water pump and spark plugs. Find a JWT ecu floating around for your setup or run a S AFC w/stock ECU and tune however you want. This way will still save you 1000 from their outrageous 3500 install and will give you a better understanding of how everything works and how to fix it if something goes wrong. Instead of forking out money everytime to take it to a shop.
Now if you don't want to go that route, then buy a JDM highport motor. You don't need to specify what kind of car you want it out of, just tell them you have a 91 or 92 se-r. They will send you a highport motor. They run very strong, cost around 450 shipped, 6 mo warranty and once again, install it yourself and save yourself about 2k.
Lastly, there is nobody I know of yet selling any VET motors. They are VE and are just as expensive as the DET w/less power and more money to make it faster. Plus trying to make that it a VE-T down the road would be a straight out PITA.
p.s.Turbo FWD cars suck at Auto X, especially high horespower ones. JDM motor, cams, intake, header and exhaust should get you what you want relatively cheap.
