IanS »
https://forums.nicoclub.com/ians-u23642.html
Sun Sep 16, 2007 3:27 pm
welcome to Nico, both of you, the easiest way to get answers to your questions here on Nico is to use the search button, the amount of info here is mind blowing.
Knowing a little more about your setup will help us solve the problem, what are you using for an ECU, is it a stock unit retuned, or are you using a piggyback or standalone. Have you noticed any other symptoms, any smoking, or spark plug discoloration? How much boost are you running? What kind of Spark plugs are you running and what are they gapped to.
again welcome to Nico
