SR20DET Parts Guide
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
Exhaust Manifold Gasket '91 Sentra SE-R w/SR20DE
T25 Turbo gaskets '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket dose not fit on S13 T25)
O2 sensor '87 300ZX Turbo
Ignitor chip '95 Q45
Fuel Injectors '95 300ZX TT (purple plugs)
Fuel Injector Seals '95 300ZXTT kit
MAF '89-'90 SOHC 240SX
transmission rear main seal '93 240sx
Slave cylinder '93 240sx
T.O. bearing '93 240sx
Pilot bearing '93 240sx
Clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1
Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC
Spark Plugs NGK BKR7ES11 or BKR6 (hoter plug)
Coil Packs '90-'95 300ZX or '95 newer Maxima
S14 SR Oil Filter '95 Sentra SE-R
S13 SR Oil Filter '91 Sentra SE-R
Fuel filter '90 300zx TT
Front and Rear main seal '91 SE-R
TPS '95 KA TPS will work with some soldering
Temp sensor S13 or S14 (depending on chassis not motor) KA24DE temp sensor
Thermostat '91 Sentra SE-R
Radiator cap '90 300zx TT (slightly more pressure for better cooling over stock cap)
Knock sensor '95 240sx
Oil pressure sender '95 240sx
The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket. Most everything else can be found locally or adapted to fit. Please add to this list if you can find or think of anything else. Also corrections are appreciated.
Paul
Movingviolation240
I got this off my old standby website Nissansilvia.com out of australia, might be of some use to you guys since Nissan seems to use a lot of the same part numbers internationally.
Part type Nissan Australia part number Other source or comments Oil filter 15208-H8911 Ryco Z145A (CA18 all?) Door bump rubbers 01658-J7000 (Skyline R31) Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner Intake manifold gasket 14035-53J10 (SR20 all) Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all) The Aust 200SX one fits. Turbo outlet flange gasket 14445-26E00 (S13 all) Engine front oil seal 13042-42L00 (CA18 all) Engine rear oil seal 12279-18V00 (CA18 all) Oil pan seal front 11121-01F10 (CA18 all) Oil pan seal rear 11121-01F15 (CA18 all) Head gasket 11044-51E00 (CA18 all) Head gasket 11044-50F00 (SR20) until 9/92 Head gasket 11044-50F01 (SR20) from 9/92 till 7/93 Head gasket 11044-50F10 (SR20) from7/93 onwards Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits Engine gasket kit 10101-56E25 (CA18DET) Engine gasket kit 10101-50E25 (SR20DET) Engine gasket kit 10101-51E26 (SR20D) Valve grind gasket kit 11042-51E25 (CA18 all) Valve grind gasket kit 11042-50F25 (SR20 all) Fan belt 11720-V7301 (CA18 all) L = 855mm Fan belt 11720-52F00 (SR20 all) Compressor belt 11920-V7301 (CA18 all) also suits power steering pump Compressor belt 11920-30R10 (SR20 all) also suits power steering pump Water pump 21010-V5528 (CA18) until 8/90 Water pump 21010-V5529 (CA18) from 8/90 Water pump 21010-52F00 (SR20 all) Thermostat 21200-V0201 (CA18 all) 82.0 C Thermostat 21200-V0206 (CA18 all) 88.0 C Thermostat 21200-53J00 (SR20 all) Radiator cap 21430-01F01 Radiator hose - upper 21501-35F10 (CA18 all) Radiator hose - lower 21503-35F00 (CA18 all) Radiator hose - upper 21501-52F00 (SR20 all) Radiator hose - lower 21503-52F00 (SR20 all) Bonnet bump rubbers (large) 62840-D0100 (Skyline R31) Engine coolant 10120-89904 Castrol Dash switch back lights Nissan Aust, have similar types $11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ). Wheel nut 62840-21001 (R31 Skyline) Brake pads See service info page. Bendix and others. Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam. Rear Dampers ( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb. Approx $315 a pair. Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1 Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm) Spark plugs 22401-53J16 (PRF6B, SR20DET) Crank angle sensor 23731-85M10 (CA18 all) Crank angle sensor 23731-50F01 (SR20 all) Coolant temp sensor 25080-89903 (S13 all) Oil pressure sender 25240-89920 (S13 all)
hurddawg
Car: anything with 4 wheels.
sr20de's timing chain will work
hurddawg
take your gates part number to any parts store they will get you the proper belt.
I did this at my local place and they gave me Dayco belts and they worked fine. The guy told me that part numbers for belts are standardized. So they can cross-reference them easily.
K050370 AltK040345 P/S
K 05 0370....05 indicates # of ribs, 0370 indicates length of the belt. K signifies its made my Gates.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Also...for those running standalones that use GM style connectors (Electromotive, etc.), a 1998 Corvette coolant temp sensor threads right into the stock sensor location and of course uses a GM style connector.
Phax
Car: Control dynamics
The crankshaft main bearings and thrust washers from a 92 SR20DE will fit a 92 SR20DET.
180fan
Car: 89 fastback
Alrighty so I can use the following 91 SE-R parts in my timing chain job?
13028-00008 Timing Chain 13070-00008 Timing Chain Tensioner 13079-00001 Timing Chain Tensioner Gasket 13085-00004 Timing Chain Guide - Tension Side 13075-00004 Timing Chain Guide Tension Side Bolt 13091-00005 Timing Chain Guide - Slack Side 13094-00003 Timing Chain Guide Slack Side Bolt 13510-00002 Front Crankshaft Oil Seal 15066-00003 Front Cover O-Ring
and those badboys will work no prob in the DET eh? I got those parts and part #'s off of courtesyparts.
thanks
180fan
Car: 89 fastback
The o ring sits behind the front cover bascially under the water pump. The timing chain tension side guide for USDM spec is better than the JDM one since the USDM one is metal while the JDM is all plastic.
The intake collector gasket is different from the SR20DE. So is the turbo inlet gasket from that of the VG30DETT. You'll have to take a file to the gasket's bolt holes to make it fit.
I'll list more erratta as I encounter them with my build up.
180fan
Car: 89 fastback
The connecting rods from the DE will work in the DET.
FYI guys, the DOHC KA and the SE-R spark plugs will work in the SR20DET. checked with NGK australia for the part numbers and got PFR6B-9 for double platinum plugs and got BKR6EIX for the iridium plugs. Checked NGK USA and found the BKR6EIX-11 are DOHC KA and SR20DE plugs.
The DET uses a smaller gap, 0.036" unlike the DE that uses a 0.044" gap but according to NGK's website gapping/closing the NGK plugs is not recommended < or > 0.08" so we can tap it closer. Or you can just leave it since I was told by HT that the gaps are the same for the SE-R as the DET.
180fan
Car: 89 fastback
Blacktop O2 sensors are the same as the 95 300zx twin turbo o2 sensors. They're the fat type that phase2 has.
turboimports
question for my redtop s13 sr20det.anyone know about the 5/6 plug on my harness for the tps? i have one like this, some say it only comes with the 50mm throttle body. wich im not sure if mine is or not. it doesnt hook up to my sr20det wiring harness, because my harness is only for 3 plugs or something. some also say that i can replace the tps with one from a 91-94 usdm sentra ser? is this right? bolt up?
thanx
-Lor
180fan
Car: 89 fastback
the SE-R's is compatable with the turbo SR's. Just make sure you've a 3 wire plug. I've not seen the 5 or 6 wire TPS for the SR's, all of them I've seen are 3.
Hijacker
Car: '92 240sx Convertible
'94 F-150
got some new part numbers for everyone. I unfortunately threw out my 5 hole turbo to O2 housing gasket bag before I could copy the part number down.
14415-17M00 4 hole gasket Exhaust manifold to turbo
32516-V5002 Shifter retainer plate gasket
ca18det_boy
MY TURN!!!!!
S14 SR
Rear Main Seal Set---------------BS 40628 (felpro)Oil Pump Screen gasket---------15053-1e400Main Bolts---------------------------12293-53j00Oil pump screen--------------------15050-53j13Pilot bearing-------------------------14658 (motormite)clutch fork springs------------------30514-14600clutch master------------------------cm39754 (tru torque)Injector O-rings (where it meets the mani)-----16636-72p00Head bolt washers------------------11058-53j00rod nuts--------------------------------12112-40f00fuel rail spacers-----------------------17522-10v00Connecting rod bolts-----------------12109-60j00Clutch slave----------------------------cs37493 (tru torque)
Hijacker
'94 F-150
here's another couple
22020-50F00 Ignitor Chip
14052-21R00 Exhaust Plug (for AIV inlet)
14064-7B000 Studs for O2 Sensor Housing
s13sr20chris
jwt says that fwd sr20de piston rings will work on rwd sr20det's. i am goint to use them on mine.
180fan
Car: 89 fastback
Front timing chain oil jet can be used from the 91 SR20DE.
180fan
Car: 89 fastback
Rocker armspart number 13257-53J03
Rocker arm guides (little grooved shim thing on top of the valve spring retainer)part number 13218-53J00
Hijacker
'94 F-150
JDM part numberCam Angle Sensor: 23731 - 50F02
Not sure if there's a US equivilant for it. The P/N for the CAS is on the cap, so this is for those of us who never received a CAS cap
cheapspeed
Car: 96 se
a 95 and up alternator will bolt to a s13 sr with some slight modification to the tensioner mounts
stiergott
Car: 240
i have a ka starter bolted to my sr. all you need to use is the ka mounting bracket. if you need more info just ask
SoCalS14
Car: My car...duh
S14 SR OIL FILTER = 15208-65F00
180fan
Car: 89 fastback
S13 SR TPS can be sourced from the 97 200sx.
180fan
Car: 89 fastback
Parts numbers
Front cover o-ring 15066-4j600
tensioner gasket 13079-2j200
front crank oil seal 13510-53j10
throttle body gasket 16175-53j00
timing chain oil jet 13081-53j00
Intake manifold to head gasket 14035-53j10
Piston ring set (std bore, #1 on block and pistons) 12033-53j20
Connecting rod bearings (blk) 12111-1n501
Connecting rod bearings (brn) 12111-1n500
s13 Oil filter 15208-53j00
Nismo transmission mount 11320-rs541
Crank bearing (blue) 12207-60j04
Crank bearing (yellow) 12207-60j03
Crank bearing (green) 12207-60j02
Modified by 180fan at 3:08 PM 10/19/2004
180fan
Car: 89 fastback
ARP Main Stud kit (arp part #) - 202-5402ARP Head stud kit (arp part #) - 102-4701ARP Rod bolt kit (arp part #) - 202-6005
SoCalS14
Car: My car...duh
Quick parts update:
Studs for attaching the valve cover:Part # 13508-53J00
Will work on Redtop/Blacktop/Notchtop
Broke one of mine, had to find a replacement...totally sucked...
180fan
Car: 89 fastback
Throwout bearing - 30502-21000
Nismo clutch fork pivot - 30537-RS540
Intake valve oil seal - 13207-D4201Exhaust valve oil seal - 13207-2B500(These two parts are from Chris' detective work, I just found the part numbers for 'em)
s13sr20chris
fwd head gasket does NOT work.
mynameisjonas
i need the throttle cable bracket, the one above the throttle body that holds the end of the cable and that you tighten the nuts down on the cable so it doesn't move. make sense? it's for sr20det redtop. is it the same one off a regular sr20de?
Asia989
Car: 90 s13.4
will the rocker arms off of a se-r 200sx fit a sr20det,same thing with the timing chain and guides if it has that?
