I've just completed my swap it's a CA18DET into a 1997 nissan hardbody. I posted up pics in the truck forms. Check it out!!!!IThaJokaI wrote:Anyone done, or thought about a CA18DET swap? I have been looking into it recently...
You did a real good job onl your swap, it came out pretty clean, i'm working on mine now, just doing more while i have the truck down. (shave and tucked bay, repaint, redo the interior), hope i see some pics of yours later down the road. I think we're both goin for the garage miniz style.oOo and i am/was a honda guy toosr20hardbody918 wrote:heres mine
ibreakstuff wrote:1- Yes, I modifed my line with a plumbing flare tool.2- Yes, the speedo will not work with the SR20. You can use 240 gauges, but they don't fit right. It will take some custom work to get them nice.3- This is about as uncluttered as it gets without running a standalone:
I did a writeup on the wiring from my truck (maybe it should be stickied?) and I'll do a start to finish writeup when I get time.
BTW the driveshaft does need to be cut and if you use the stock motor mounts the engine will sit wrong.
Stank wrote:Ok, I have a 90 D21. Not ant different than steve's. I got the sr20det with ecu, harness, trans, and sensors. I understand mounting it into the bay, the engine mounts appear the same. The drive shaft hooks right up. My questions are, for starters.
1. Do I need to move the power steering?2. Do I need Different Gauges?3. The clutter in the bay from the ka24, can that be removed or is it required for
The chassis on the 87 hardbody should be the same (wiring will be different) and I don't see why you can't run an SR in a 4wd truck.
Modified by Stank at 1:22 PM 9/2/2007
