CoupedUp »
https://forums.nicoclub.com/coupedup-u58258.html
Thu Aug 09, 2007 11:47 am
Yes, you can wire up your fans just like I did, as soon as the key is in the "ACC" position the fans will come on.
On the Relay box on the driver's side of the engine bay. Look for the "ACC"(Accessories relay). You'll need to disassemble the Relay Box to get at this relay from the bottom side. If you aren't using A/C or your Pop Up Headlights(Silvia Front) or I suppose you could go buy a 30 Amp Automotive Relay. You can use either relay Cut one of the two relays out and leave a decent section of wiring out to solder too.
Now on the "ACC" relay there is a Signal wire and the Signal ground. Find the Signal wire by disassembling the Relay and looking inside of it for the numbers by the 4 Pins. Then match to that of the diagram on the head of Relay. There should be:
"# *Line with Break* #""# *Line with Squiggly* #"
Now the Signal wire is the lowest number associated with the "Line with Squiggly". You need to tap into that wire and run it to the same equivalent on your relay. If its a nissan A/C or Headlight Return Relay, Odds are its EXACTLY the same. Wire it to the lower of the 2 numbers on the "Line with Squiggly"
Now you can take higher of the 2 numbers on the "Line with Squiggly" and you can either run the Fan Relay Signal Ground to the "ACC" Relay Signal Ground. Or You can ground it out to the Chassis right behind where your drivers side headlight has lots of chassis grounds. You'll see it. I hope.
Now, you'll need some pretty decent gauge wire. Go to Radioshack and buy some decent wire and a package of Ring Connectors for the end of the wire. You're gonna be attaching this to your Battery terminal so size it according to the stud that 10mm nut is on on the Positive Terminal. You'll run your wire from the positive terminal to the Fan Relay you are making. Attach it to either side of the 2 remaining wires on the Fan Relay. Now lengthen the other end of that last wire remaining on the Fan Relay and run it the power wires of your Fans. Wire in your thermostat how you'd like and set it however you'd like as it won't turn on randomly. Now ground your fans to Chassis.
And In the end it should look a little something like this.
