leroiboy wrote:chicos, i emailed you-thanks. tiger-sorry for the gender insensitivity , im trying to get with someone with an ecu i could swap and try and ill also try an ignitor too. so do you mean to simply pull the cas out of the head and just turn the shaft, and i should hear the injectors click? thanks again. also as a side note, me not having the o2sensor unplugged(waiting for new one to arrive-last one got the wires snatched out of sensor) would cause any of this, would it?
Modified by leroiboy at 10:29 AM 4/27/2007
Modified by leroiboy at 10:34 AM 4/27/2007
Hey, well yes.. pull the CAS out.. and connect it to the wiring harness and spin the gear on it and listen for the click, click, click, click... each injector should click.. I guess make sure your key is turned once or twice, I dodno.. it has been about 2 years so i'm pulling this all from memory.. if your ignitor chip is bad it wont click but if you h ave spark then your ignitior chip is good.. duh. hehe. Dang I hope u get it figured out.. there has to be another person with an SR20 near you... even someone you don't know might let you use theirs for just a second... who knows. nah the o2 sensor unplugged would not cause that... if you have spark your ignitor chip is good, so dont worry about that.
I bet the ECU is bad !!!
