SR Bellhousing Bolt Pattern vs. L20B
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Can anyone tell me how different the RWD SR 5-speed bellhousing is from an L20B 5-speed? Does it require the use of an SR transmission or can an old Datsun competition transmission still be used after the swap?
Hijacker
Car: '92 240sx Convertible
'94 F-150
With an adapter plate, you could use the L20B trans. The bolt pattern between the block and the bellhousing are pretty different, if I remember correctly. I would see about having someone mill up an adapter if you really need to use the comp trans.
Rev_D21
Thanks for the info. The owner really wants to use the Datsun transmission because it has a 1:1 5th gear and he's doing land speed stuff.
