Squealing Noise From Front Driver's Side Wheel-Well
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
As the title states I've got this horrible squealing sound coming from my front driver's side wheel well. The sound temporarily subsides when I engage the brakes. Recently I was low on brake fluid which I'm guessing is because I didn't bleed the lines the last 2 pad+rotor replacements and maybe the excess air finally made it's way to the top of the system? This is a wild guess. Could that have anything to do with this? Has anyone experienced this?
Thanks guys!
fueler
Car: 2 Nissan's
2 BMW's
my money says worn brake pads. How many miles do the pads have? Did you ever have a squealing before that mysteriously went away?
Pads have a wear indicator that makes noise, in an effort to scare people into bringing the car into a shop. The indicator eventually breaks off though, and then you should get new pads ASAP.
Empty V
fueler wrote:my money says worn brake pads. How many miles do the pads have? Did you ever have a squealing before that mysteriously went away?
I replaced the pads last year so probably have abut 20K miles on them. I never had any squealing before. I thought squealing only occurred when you applied the brakes, not when you're accelerating.
fueler
Car: 2 Nissan's
2 BMW's
nah when pads get low, they squeal when youre moving but the noise goes away when you press the brake...
if they're performance pads, they might be almost done at 20k miles
Empty V
fueler wrote:nah when pads get low, they squeal when youre moving but the noise goes away when you press the brake...
So I guess that would explain the squealing noise, which would explain the low brake fluid level, which would explain the parking brake light being on because of the low level. Thanks Adam, you rock bro!
B-Money
