Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Sat Aug 21, 2004 7:01 am
I wanted to recreate this thread in case anyone had other suggestions.
Here's a repeat of what was happening:Randomly, at stoplights, the idle will fluctuate, and either go back to normal or die. I often have to put less pressure on the brake, turn off headlights, or turn off the AC or fan to keep it from sputtering out. When this happens, it sometimes briefly says "Low Battery Charge". There's also a strong fuel smell that comes into the cabin, then goes away.
Also, under normal acceleration at 30-50mph, it will sometimes start bucking -- and not necessarily when its about to shift. (I think that might rule out a tranny issue).
Suggestions I've received so far are to gently tap the MAF (to see if thats the cause) and leave the battery disconnected overnight.
The problem began weeks ago and has been slowly worsening. Any other ideas would be greatly appreciated!
Thanks,-Jesda Gulati
