I second that. Had they been available in my current size, that's what I would be rolling now. Had them on my M35 and loved them.szh wrote:If you do not ever drive in close-to-freezing conditions, then the Michelin Pilot Super Sport is an awesome tire to get.
Z
Is it really only if they are driven in those temps? I was told that the compound will actually freeze and change chemistry somewhat just being in freezing or near freezing temps and that is what makes the tire bad from then on.szh wrote:If you do not ever drive in close-to-freezing conditions,
Well, yes. But the danger does not matter unless you were to try to drive at those temperatures ... if the tire is frozen and you are not actually at speed (although parked on a hill might be an issue too, I suppose), it is not an issue.EniGmA1987 wrote:Is it really only if they are driven in those temps? I was told that the compound will actually freeze and change chemistry somewhat just being in freezing or near freezing temps and that is what makes the tire bad from then on.szh wrote:If you do not ever drive in close-to-freezing conditions,
TDOT, you will be happy with the Hankook Ventus S1noble2. Tire Rack was running a special, maybe they still are. I had them shipped to the shop I use to install - ordered on Friday and they arrived at the shop on Tuesday. I also recommend the 255 size (maybe wider since you'reusing 20's). They make a big difference in appearance.TDot wrote:Ok, so this is what I'm buying. Let me know if I can get any of them cheaper please, or f I'm missing anything.
Vossen cv4 or cv5 20" = $2300
Hankook S1 Ventus Noble2 tires (4 x $177.47 + shipping) = $806.94
Front strut left = $103.31
Front strut right = $103.31
Rear struts (2 x $63.04) = $126.08
Tien H-Tech lowering springs = $217.79
SPC Upper camber control arms = $385
SPC Rear camber adjusters = $88
total = $4130.43
you may not need the rear camber arms or bolts with the H-Tech springs, this would save you about $180 + installation. Even the X needs a little camber at the rear.TDot wrote:Ok, so this is what I'm buying. Let me know if I can get any of them cheaper please, or f I'm missing anything.
total = $4130.43
