Zion8561 »
https://forums.nicoclub.com/zion8561-u28751.html
Tue Apr 18, 2006 6:59 pm
Ok, I installed the SS SPL clutch line today, and did the damper bypass. The hard line bent a lot easier than I thought it would (I used a line tool so it would not kink up).
One note about clutch bleeding I learned the hard way: After doing the maintenance I went to bleed the clutch, but the Master cylinder had emptied...I filled it up, but no pressure would build (clutch pedal would just swing freely, and even stay on the floor) and fluid level stayed the same.
I took the bleeder screw all the way out of the Slave, and let it sit for about 5 minutes to let the fluid gravity feed into the lines. Then I topped it off and cycled the clutch 3-4 times with the bleeder completely off, then reinstalled it and bled normally with good pressure buildup. Maybe this is common knowledge, but this was my first experience with a hydraulic clutch job.
