speedometer
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
coleeluke
Car: 1978 Datsun 620 longbed
I have a broken speedometer on my 78 620 and was wondering if anyone either knows how to fix it, where a replacement might be obtained, and if speedometers from other Datsuns would work if I can't find one from a 620. I just bought the truck and the previous owner said he had just replaced the speedo cable and it still won't work.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
coleeluke wrote:I have a broken speedometer on my 78 620 and was wondering if anyone either knows how to fix it, where a replacement might be obtained, and if speedometers from other Datsuns would work if I can't find one from a 620. I just bought the truck and the previous owner said he had just replaced the speedo cable and it still won't work.
I get mine for like 7.99 at autozone. Use the original key thingy that slips into your transmission and cut the new cable to length. You will have to uncrimp the part the goes into your transmission and pull out the old cable...takes a little effort, but then you carefully re crimp it onto the new cable. I got mine working that way.
Welcome to the forum BTW
TrevDaddy
Car: 1973 Datsun 620
Speedo on mine is also out. Ordered a while new cable from rock auto, hopefully it fixes the problem. I also have no dash backlight at night, what could be the problem?
PEZi
i'm not too accustomed to 620 wiring... but for the dash backlight check the fuses and does it have fusible links? if so there may be a short somewhere or something
S13 Madison
Car: 1993 240sx hatch
my dash backlight was also out.my problem was my light switch was worn out and turned faulty.just pull out the switch and clean the connections. And my speedometer doesn't work either.i have a black top s13 srand idk where to start to fix the problem
Return to “Datsun 620”
