speedo gauge required??
DepPravacion
Car: datsun 1200 pickup Sr20Det
whats up Nicoclub.
in a bit of a time crunch so i will just post this question now.
sr20det installed into a datsun 1200 pickup.
is the speedo gauge required for the ECU to function properly or is able to be deleted with no issues? i realize this may be covered already, and i myself frown on redundant posts but as i mentioned i am in a bit of a time constraint so just looking for a quick response if anybody can help.
thanks
cheers
Hijacker
Car: '92 240sx Convertible
'94 F-150
Not required.
DepPravacion
thanks for the reply.
i found that the speedo actually does have a small play in the engine management but still able to drive.
I actually got lucky at the local surplus store and was able to source a silvia cluster.
Hijacker
'94 F-150
It should only tie in for the speed limiter. The VSS sends its signal directly to the cluster and then the gauge should just send a single wire signal to the ecu. That wire is more or less a switched circuit to the ecu.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
My SR powered S13 has no speedometer and has never had an issue with it. Hijacker nailed it.
