spark plugs???
240man91
Car: 1991 nissan 240sx se hicas
Ok quick qustion, what plugs should i run in my kat? It is 9:1 compression with 18psi of boost an 264/264 cams. An gap size if anyone knows.
WDRacing
http://www.frsport.com/NGK-Iridium-IX-S ... _3102.html They have the heat ranges right there in a drop down. Use a cold plug to avoid pre-ignition. I'd run a 7 or 8, the cooler the plug the worse it runs in cold weather and they are less efficient for idle, but they are a must for boost. I use Iridiums, have since 99.
240man91
Yeah i those will work i was wantn to get them from like auto zone
neverlift
I personally use copper ngks heat range 7.. I can buy 4 sets of plugs for the cost of one set of iridiums.. But I am notoriously cheap :crazy:
240man91
Yeah i dont realy car how much they cost just want to but the from a parts dealer near me like auto zone an part number would be cool if any one has one
neverlift
NGK BKR7E
#4644
for the copper
IDK on the iridium
WDRacing
Here's a list of NGK plugs with part numbers and prices from NGK's site. See where it says, BKR5EIX-11 for the iridiums? Change the 5 to a 7 or 8 for a colder plug. I didn't see the coppers listed.
NGK - KA24DE - 240SX Part Numbers.
Here's an awesome spark plug cross reference.
Summit Racing 240SX Plugs
WD
240man91
Thank you very much just what i needed!!
240man91
Ordered throu o'reillys an gotn in the same day for 30 bucks. Thanks agen guys
WDRacing
:werd:
