Ghost_54 wrote:Replacing the rear plugs if they have not been changed was what I was referring to, that and because you will be really pissed if a month later after doing the plugs you through a misfire code for one of the rear coils and you now have to remove everything again to gain access. As for oil in one of the chambers it would most likely be #5 (crappy 03 valve cover develop hair line cracks inside) the 6th gen version resolved that issue. Markc have you also done the VIAS delete for a block of plate? very nice little mod you get a very smooth linear pull straight through to red line RPM range.
I tried one b4 I had the spacers and Cattman ypipe and didn't like it. So I took it off and sold it. I now have a non NWP plate, ( from someone in competion with NWP). I only bought it from him because shipping was only 5 bucks to Canada. It's a POS. I have to remove the sharp edges from it b4 I install it, and, it's getting cold out. It may not go on till next spring.
