Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Wed Sep 24, 2008 11:16 am
Heat range 6 works, but 7 might be ok too. It's a balancing act with plugs. They need to be cold enough to remove heat from the cylinder, but not too cold so they foul.
Definitely go .034 or so. .044 will detonate at that boost. If you go lower than .032 or so, it may not idle well., especially when it's cold.
