Spare Tire Pressure (psi) Have You Checked It Lately?
I FOUND MY SPARE TO BE 40psi TO LOW!!
I figured, since many of you will be hitting the highways- i offer you a tip that i just came across myself as something to be weary about. We all know our Nissan Rogue has a tire pressure monitoring system (TPMS for short). But what many of us dont know - is that it does NOT judge the tire pressure in the SPARE TIRE. That being said, before you folks hit the road, head up to the local gas station (or if you own a compressor) take a reading on the spare tire. You dont want to be stuck out on the open road - with a flat, that you cant repair because your spare tire is to low to be used.
In this segment i will cover the removal and proper inflation of the spare tire.
1. open your trunk. and clear everything out.
2.open the part with the cloth pull tab
3. take that string & hook and hang it off the rubber seal as in the next photo.
4. next open the divider in and twist the 4 plastic tabs to release the divider from the trunk area.
there will be 4 in each corner of this divider.
5. after twisting the tabs, and releasing the divider tray, remove it with a gentle tug & place it on the ground
6. next twist this gray turning knob COUNTER-clock-wise to remove the BOSE subwoofer from the wheel.
7. gently lift the subwoofer up:
8. place the subwoofer gently (dont tug on the wire) on the lifted rear cover like so:
Mine was found to be at around 20psi-25psi
NOTE: (canadian models have a full size spare so PSI will be different = around 32-36)
here in the US - we have large donut spares. our PSI is going to be 50-60psi(max).
I PREFER TO FILL MY DONUT TO THE MAX, SO I KNOW I HAVE LONGER TO GO BEFORE NEEDING TO RE-CHECK.
60psi IS THE MAX PRESSURE FOR THE DONUT SPARE. YOU CAN ALWAYS LET A LITTLE OUT IF YOU NEED TO USE IT
IMMEDIATELY AFTER FILLING IT. (just insert a pen tip, or key into the valve and push down till you hear it- for 2-5seconds.)
HOW TO CHECK TIRE AIR PRESSURE & HOW TO FILL: (courtesy of eHow)
[youtube]
http://www.youtube.com/watch?v=hk28u7NTlsE[/youtube]
now just follow everything in reverse order and your done! now you are ready for any road trip!
