Some adapter plate updates
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
Well the prototype vh45 and vh41 adapters are in!
vh45 to ka, vg, z33 and z34 transmissions
vh41 to the same options
They will be available soon from the guys at www.swap1uz.com!
IThaJ0kaI
Here is a post from the man behind the plates, from another post on here.
1UZ240 wrote:I just made both of these adapter plates. Yesterday, and they are really similar, but I just made two different adapter plates specifically to get all of the bolt holes I could. The oil pan bolt holes are different not to mention, the VH41DE has that huge notch out on the passenger side that I had no Idea what that was for, but anyway I have two different adapter plates for either one of these engines. I'll take some pictures and get them up if you guys want??
The adapter plates that I made last night have the following transmission bolt patterns in one adapter:
VH41DE engine to 350Z 6-speed transmission (CD001,Cd005) bolt patterns, 370Z 6-speed(CD009) bolt pattern, KA24DE 5-speed bolt pattern, and Z32(300zx) bolt patterns all in one plate.
VH45DE engine to 350Z 6-speed transmission (CD001,Cd005) bolt patterns, 370Z 6-speed(CD009) bolt pattern, KA24DE 5-speed bolt pattern, and Z32(300zx) bolt patterns all in one plate.
IF you guys have questions(which I'm sure you will) just email me, since I never go on the forums as much as I used to
[email protected]
willko1
Car: 2000 q45 y33
WOW that is awesome!
IThaJ0kaI
And they're done.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I hope someone takes you up on these and converts a Q45.
smpresco9027
Car: 1995 q45 non-active
How much are you charging for these? Any modifications need to be done like welding in studs? Are you spacing out the flywheel for these plates?
hk20000
Car: 1996 Infiniti Q45t
Just after I put my whole shebang together with Wes's plate on a Z32 5 speed too.....
Now I want a 6 speed. God damn it!
IThaJ0kaI
maxnix wrote:I hope someone takes you up on these and converts a Q45.
Both of these plates are being used in Q45s, the 6 speed is going into my G50 and the 5 speed into my room mates Y33.
smpresco9027 wrote:How much are you charging for these? Any modifications need to be done like welding in studs? Are you spacing out the flywheel for these plates?
I am not selling these, http://www.swap1uz.com sells them now. He made the original plates for me and my room mate. The only mods needed is 5/8" removed from the bellhousing plus a small notch to clear the starters depending on transmission. No flywheel spacer is used, you use a z32 NA flywheel with the Q45 starter gear.
hk20000 wrote:Just after I put my whole shebang together with Wes's plate on a Z32 5 speed too.....
6 speeds are sweet!
Dont forget, these plates are not just for a single transmission. Both plates are for KA, z32, z33 and z34 transmissions all in one! So you just order the plate then decide what transmission you want!
Q451990
I can see the future... me ticked off about my A/T giving up the ghost and reading this thread... :D
Good work!
Heath
smpresco9027
Thanks for the response. My AT is acting weird even after servicing it so I'm going to swap it. As soon as I sell my truck I'm going to contact the guys at swap1uz.
IThaJ0kaI
Just a small update.
Anyone with a G50 looking to swap to a 6 speed, you use your stock transmission bracket! All you have to do is weld in 2 washers, or just a plate with 2 holes and it bolts right in!
