Ceptos wrote:how much would something like this cost? it cant be all that cheap, can it, dont you have to take out the engine to replace the pistons? or at least be able to come at the pistons from above and below to replace them. unless you are doing it yourself, would this be exspensive?
Expensive is a relative term. Since you're replacing pistons, you'd want to at least go through and check the crank and assembly, maybe replace the rod and main cap bearings. Depending on tolerances, maybe a light bore to get the clearance right in the cylinders. Other things will come in to play to push the price up, head gasket, etc, so it could get expensive, but much less than a full rebuild, or mild headwork. You would also want to a little tuning, maybe with an ECU upgrade, to compensate for the higher compression.
