And I bought this instead!
http://www.youtube.com/watch?v=Ef-8dlY4X5I
Definitely not a smart choice, but, I'm a car guy dammit!
Mod list:
Engine
New LS6 block, balanced 383 stroker, 8:1 CR
Compstar 4.00 Stroker Crankshaft
Diamond forged pistons
Modified fuel system (no return) with adjustable regulator
Callies Ultra rods
All bolts and studs are ARP
ATI dampner
Underdrive C5 pulley
CAM: 228/238 .571"/.585" 113LSA +1 advance
Comp XE/XE high lift lobes 3717R/3652R 113LSA +1 advance (112 installed intake centerline)
Magnuson 112 supercharger
Alky control methanol injection
MSD coils
Maf delete with speed density tune
Volant CAI
HP motor mounts
Stainless Works headers with Corsa exhaust (high flow cats, gutted), I also have X-pipe that is not installed
Lingenfelter two stage with rev limiter
Heads
Ported and polished by BES engines
Patriot Gold Dual springs with Ti retainers.
Comp cams 7.450 pushrods with Yella Terra rockers
Transmission
RPM stage V
Hurst shifter with Liberty handle w/button
Drivetrain
Custom subframe connectors
Adjustable drag shocks (stock struts and shocks included)
Custom C3 rear end with 3:90 Richmond gears
HD halfshafts
Misc.
Line Loc
Autometer Pro stock tachometer w/memory
PLX modular AFR andBboost gauges
Custom underhood, trunk, front, rear mats with embroidered headrests
New Optima battery relocated to trunk with NHRA shutoff rod
New GM optional wheels with new tires
Dynamat on all lower surfaces
All original Cadillac options working including stabilitrack and TC control
EFI Live Tuner with software and all licenses and current tune.
While I was at the drag strip, two cars from the tree, I hear the tick from the engine echoing off the garage like building next to me, I got it towed home and then later to the local speed shop. Collapsed lifter... damn, 700 miles into the car (I drove it home from Alabama). Problems with a car of this caliber is expected, but I wasn't expecting them so soon, lol. The guy at the shop is modifying a few things and throwing on the dyno for a tune, I should have it back this weekend!
