Thank you everyone for the replies!
Fezzik wrote:Let us know about the redline. I use it as well. I used to blend mt 90 to get a mt85 mix which is what our car wants, but now redline makes it. Look it up. Get the mt -85. Its what i used from when the car came off the lot and no problems.
I did the MT flush yesterday. At first I opened the filler plug and the fluid that was in there came out in a solid stream, so the shop had overfilled the MT. I let that drain off completely, closed it up, and drove the car around. The notchiness did get slightly reduced, but it was still hard to get into gears at a completely stop. I flushed the fluid out completely and put in 2qts Redline MT90 and roughly 1.1qt MTL, and I made to let it drain off completely so that it wasn't overfilled. The notchiness shifting through gears while moving did go down a bit, but it is still hard to put the car in gears while at a stop.
5.56 wrote:i know there was a throttle control issue with these cars (i used to own a 2010 g37s coupe 6mt). it required a flash with some upgraded program.
i would start with every possible area, and work my way back:
1. intake system: MAF (air intake temp sensor if separate from MAF), throttle body(clean, replace), and since the PCV system is related to the intake manifold, i'd start cleaning and replacing valves, hoses, etc.
2. exhaust system: check the temps of the cats. make sure they are not getting too hot. that could be the result of clogged cats, thus robbing you of power. place them if they are running too hot.
3. fuel delivery: start with the fuel pump, fuel filter(if equipped), injectors(replace the or send them out for ultra-sonic cleaning).
4. brakes: check for sticky calipers. go for a safe but 'spirited' run. check the temps of all the calipers. maybe one is sticking?
To do the flash/program upgrade, did you just have the dealership do that?
As for your suggestions: 1. I've cleaned everything, MAF, intake filters, throttle bodies, intake piping, and ran Seafoam through the intake manifold via the brake booster line. After all that I used the "without CONSULT" procedure in the FSM to do the Idle Air Volume Relearn. the car settled back into the 650rpm idle that it should be. Doing all that has no affect on the situation. I have heard the throttle bodies on this car are rubbish, but I haven't had much luck with testing them to verify proper operation (been thinking about just replacing them). I need to go further and check the PCV valves and hoses (a project for when I have enough time).
2. Using an infared temp gun I checked the temps of the cats and the piping before and after. Fully heated up the cats were around 300F, piping before was around 500F, piping around was around 250F. Not sure if those are good numbers though...
3. I had a shop conduct a fuel injector cleaning, but all they did was connect a pressurized can of cleaner to the PCV valve and force that through the fuel rails and injectors. This had no affect, so i don't even know if it mattered. Another side project I want to do is to go and pull the injectors and inspect/clean or replace. The fuel filter is embedded in the fuel pump and does not require replacement unless the pump goes. I need to troubleshoot this still.
4. Brakes are not the issue. I have the Racing Brake upgraded kit for the Sport brakes and I installed myself. I check the rotors frequently for warp and already checked calipers for proper operation, so that has been ruled out.
float_6969 wrote:The loss of power sounds like ignition retard. Will the Accessport allow you to log ignition timing for long enough to capture the ignition timing when the issue occurs?
As for the transmission, I know this sounds crazy, but go back to whatever Nissan used for the transmission lubricant. I have not had good luck with synthetic gear oil in my transmission for the same problems you're describing. My theory is that the synthetic oil is so slippery, the synchros don't work as they should, and so it's hard to get it into gear because the synchros have trouble getting the gears lined up to each other.
I'm going to check the shifter assembly to make sure everything is the way its supposed to be. If that doesn't change anything then I'm going to go back to the Nissan fluid for the MT. As for the Cobb, it had a reading for timing, but that stuff is still too advanced for my level, so I didn't know what I was looking at. At this point I got rid of the Cobb because it corrupted my stock ECU. I have been thinking for a while now that either my timing is screwed up and the ECU has been retarded the timing, or I have an issue with the VVEL. For something like that I want to find a good local tuner to check this out for me, but I haven't found a good one yet.
