Papadirty wrote:I went out today to look at a GT-R already in Canada. Now I have a few questions.
How hard is it to work on a skyline? As far as upgrading parts go well I be able to do most of it myself? I've been working on cars since I was old enough to walk and I'm working on my automotive mechanic trade this year and next year.
Would it be daily driver material?
If a skyline is suppose to be all about power, and makes number around 270hp stock, how come the speedometer only goes to 180 km/h? Seeing my accord has been speed trapped at 268 km/h I sure hope that a skyline could do better.
Is it adjustable AWD or 100% rear to 50/50 split?
What should I be looking for before I buy this car? It's a 1993 GT-R with twin turbo 100% stock with 73k kms on it.
Thanks in advance
First off, congrats on a possible purchase. Now, let's get some of your questions covered right quick.
The power is rated at 280ps (276hp) because during the time the R32, R33 and R34 were made, there was a gentleman's agreement that stated no cars could be advertised at producing more than 280ps. In reality, the R32 puts out closer to 300ps at the flywheel.
The AWD is a computer controlled unit with sensors that monitor wheel slippage. Under normal driving, the GT-R is a rear wheel drive car. Under hard acceleration or hard cornering, if needed, the car becomes AWD with about a 30%/70% front/rear distribution of power.
The speedo only goes up to 180KM/h because in Japan, all cars are speed limited to 180KM/h through the computer. It's possible that this car you are looking at could have had it's ECU tuned and the speed/rev/boost limiter removed. Also, some GT-Rs (i.e. Nismo trim) had 320KM/h speedos.
On the drivers side of the engine bay, you'll find the cars factory boost control solenoid. On one of the hoses, you'll see a yellow stripe. Inside that hose, where the stripe is, is a brass orriface that maintains the boost on the R32 to about .75bar. If you remove that restrictor, you can increase boost pressure to 1.0bar (14.7psi)...but be very carefull doing so. Prolonged runs at max boost with that restrictor out, you'll over heat and grenade your turbo's ceramic exhaust wheel.
I'll give you more info when I have time, but you have a bit to get you started.
