Fasteddie01 »
https://forums.nicoclub.com/fasteddie01-u61130.html
Wed Feb 10, 2010 5:26 pm
Just a late note here, if your knock sensor is OK (check the codes) then you can get away with low octane if you don't run hard. If the knock sensor picks up a knock, it'll retard your timing until re-set or re-learned, and that'll cost you a lot in poor mileage. Get codes read to check KS soon, you may be in trouble already, it's a 'ghost code' that doesn't set off the CEL. If KS code is there, you can fix it with a 'resistor mod' instead of the KS (about $50 or more), but then you really have to be careful about gettin' down on the gas.
