pm_page6776 wrote:The knock sensor will not turn on your check engine light
It most certainly will.
To the OP:
The knock sensor will throw a fault code of PO325-PO329 in your car. You may also have another contributing code with this. Possibly the MAF, EGR valve, or O2 Sensor. These component failures will sometimes cause your car to run abruptly. This will also trip your knock sensor, many of the times. My advice, is to leave the knock sensor alone.
The only time you should replace your knock sensor is if your ECU is reporting a knock sensor code only, and only after clearing the knock code several times should you consider changing it. The knock code gets thrown along side other codes very often.
The knock sensor is important if your have a major problem with your car. Major misfires, timing, etc. These things will grenade your engine. If your engine is running smooth, then I wouldn't worry about the knock sensor. However, If its running rough and sputtering, I would look into the fix. Remember, the knock sensor only lets you know there is a problem somewhere else in the car. It not the problem itself
