where was the fuse? I'll check that out later and report back.body80 wrote:Another important thing that I personally found out.
If the fuse for the rear tail lights blows the shifter will not move out of park.
Pathfound49 wrote:A half-assed repair job can be done by removing the cover surrounding the shifter. On the passenger side of the shifter, you will see a white plastic assy. with a metal pin in the back of it. This is where your shifter unlocks. When you press the brake pedal, you should see the pin slide in and the top of the assy. pulls down to unlock the shifter. With the switch in this position, you can insert a 1/2" long piece of 3/8" vacuum hose between the switch and the shifter plate to lock the assy. in the open position. No more brake pedal needed to unlock the shifter. Disclaimer:Do not do this if you have children riding with you on a regular basis.
If I get a chance, I'll put up some pics.
Nope, the silver trim stays in place. You are going to remove the wood-grain trim around the silver shifter base plastic. It should just pull right up.D13_R50 wrote: yeah.. im not doing that..
just tested the tail and brake lights, they all work properly
and to clarify, i remove the silver plastic around the base of the shifter right?
So pulled off really easy . I tried applying the brake slowly, listening for some sort of sound, and didnt hear anything come from there. So where exactly is the solenoid? I dont think i saw it just removing the trim piece thoughPwnin O'Brien wrote:Nope, the silver trim stays in place. You are going to remove the wood-grain trim around the silver shifter base plastic. It should just pull right up.
Sorry about that, didn't realize it was an LE. Here's what yours looks like...D13_R50 wrote:The layout of my shifter is different from the one in the pic, my shift lock hole is on the driver's side.
ill get a pic up later
Ohh there we go. Okay, so when I push down on the brake, there isn't any movement coming from any of the parts. Does that mean I've got to replace that solenoid or the relay?Pwnin O'Brien wrote:Sorry about that, didn't realize it was an LE. Here's what yours looks like...
You removed the screwdriver before pressing on the brakes to test the solenoid, right? You could start by testing/replacing the relay that powers the solenoid; as you probably already know it's the relay in my image above. If that doesn't work then you may need to replace the solenoid. Without a multimeter there really isn't an accurate way to test parts. However, if you can't hear the relay clicking when you press on the brakes then the likely culprit is the relay. If you can hear the relay click when you press on the brake pedal then your issue the the solenoid.D13_R50 wrote:Ohh there we go. Okay, so when I push down on the brake, there isn't any movement coming from any of the parts. Does that mean I've got to replace that solenoid or the relay?
My dads got a screwdriver jammed in the shift lock to allow the shifter to move "properly"..
Yeah, I removed the screwdriver. Is it a constant clicking, or just one? When I was testing yesterday, there wasn't any click or any noise when I pushed on the brake.Pwnin O'Brien wrote:You removed the screwdriver before pressing on the brakes to test the solenoid, right? You could start by testing/replacing the relay that powers the solenoid; as you probably already know it's the relay in my image above. If that doesn't work then you may need to replace the solenoid. Without a multimeter there really isn't an accurate way to test parts. However, if you can't hear the relay clicking when you press on the brakes then the likely culprit is the relay. If you can hear the relay click when you press on the brake pedal then your issue the the solenoid.
i have this problem where i can't get out of park but when i press the brake i get the clicking sound so does that mean i just need to replace the solenoid? or can i just replace the stop light switch like rommel2011 did?Pwnin O'Brien wrote:It will be just one click right when you start pressing the brake pedal and another click when you release the brake pedal.
