A.Tech »
https://forums.nicoclub.com/a-tech-u53558.html
Tue Feb 20, 2007 9:31 pm
So I came under the thought that well since it is about 10-30 degrees out there everyday here in New England during winter. My Shifter is hard to move. When I get into my car start her up, my shifter is very very stiff until warm up or driving, even when I wiggle her in neutral(which is kinda odd) she is stiff.
It like as if the gear oil was way too viscous(thick). IT will get better as I drive and all, but I don't think it is too good for the tranni for me to drive under higher viscosity oil while it warms up because the gears don't get the lube they need as I shift or drive.
I had it changed about 4 months ago @ a transmission shop because I did have the time to do it myself(Was only $30 bucks) and they put 80 weight in my tranni. It was just gear oil though. That is what there computer came up with so they did it cause I did not knew what type of standard transmission oil it too.
Could this be a wrong type of oil added for the winter? IS the oil too heavy for the winter? Can I add something or completely change this oil again to something lighter? I know winter is almost over(Thank god) but I still don't want to risk any Transmission gears or Syncros to get bad on me do to lack of lubrication...
Thanks...
Modified by A.Tech at 1:45 PM 2/22/2007
