My motivation came from MINES in Japan. They have a harness to do this mod without having to cut any wires. here's the link
http://www.mines-wave.com/JP/C...RNESSand here's the pic
What is this mod and why did I do it? This mod changes the manual mode shifting direction. Forward for a down shift and back for an up shift. If you are an avid performance enthisiest you already know that the down shift and upshift shifting is backwards on this car when in the manual mode. If you don't beleive me go out and do some serious braking and feel the natural tendancy your hand has to move forward. If you accidentally perform and upshift durring braking you run the risk of loosing your engine braking, unsettling the chassis and possibly missing your mark in you turn in or even worse yet would be an accident or uncontrolled slide.
This was a pretty easy mod, but depending on how you want to do it you can complicate it as much as you want. I went the simplest most direct and effective method possible.
This mod requires some removal of the interior trim peices. I was successful and did no damage to them during removal and installation, but with any R&R there is a possibility of damage. Be careful when performing the r&r.
this is the wiring scematic for the auto shifter control. these are the wires needing switched
Here is what you are looking at when all the necessary trim is removed. The circled item is the M133 connector
Here is the actual switch(s) used for the shifting action
Here is the plug unplugged and shown the backside wires to change out. this actually shows the physical representation of the wires to switch from what the wiring diagram shows.
What I did was try to take apart the connector and just switch the wires, but it turned out to be more difficult than I thought so I took the easy way out and just cut the two wires shown - yellow and green wires - and stripped them and switched them. You may need to add your own extensions to the factory wires to not stress out the connectors and soldering at the switches, but you can easily do this with some same size black wire to keep it looking stock. I forgot to take a picture of my finished result, but you'd have to be very particular to figure out that I changed anything and I doubt even a factory technition would notice it. The nice thing about it is that the factory uses black electrical tape so to switch back to stock it wouldn't look suspicious if you use it.
Here is a video of the shifter in action, I know it's a little blurry but you kinda get an idea of what the switches do.
http://s35.photobucket.com/alb...8.flv
Modified by ken in az at 6:16 AM 1/16/2009
Modified by ken in az at 6:17 AM 1/16/2009
