Shift knob replacement
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
versaman125
Car: 2009 Nissan Versa 1.6 5 speed manual
How do i remove the stock shift knob to put a aftermarket one on?
viet510racer
Car: 08 Nissan Versa SL
versaman125 wrote:How do i remove the stock shift knob to put a aftermarket one on?
there are a couple of post about this in the search, but all you do is pull up and there will be a plastic piece on the shifter shaft that you gotta get off.
can i ask you which shift knob u going for?
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Nismo has some nice looking shift knobs if you're into something clean and simple.
reyes1212
Car: '07 Nissan Versa Super Black
VersaMG08 wrote:Nismo has some nice looking shift knobs if you're into something clean and simple.
I really want a black Nismo one, but unfortunately all their models are screw-ins, not tapered. Versas don't have a threaded shifter shaft...unless you were to buy a die cutter or whatever they are called that MAKES a thread. If you went that route you would have to find a die that cuts a thread in 10mm because that's what most shift knob's thread pitch is.I was about to thread my stick, but ended up not when I got a refund for a Nismo knob I had ordered before lol
Return to “Versa Technical Discussions”
