Well, from what I've gathered, the cylinders go as follows for KA24E:
Front of engine: 1,2,3,4
On the cap:
43
21
Firing order: 1,3,4,2 in a counter clockwise motion.
Actually managed to find a factory KA24E at a junkyard still intact with the wires still ran and a factory cap!
Got the car started too, and did some adjusting on the distributor and TPS, and it seems to be 10x better now!
However, one thing I did notice I couldn't manage to get the TPS to read 0.5v @ closed throttle? What I did was disconnected it at the actual plug on the TPS, not the dangling wire off of it. Then, ran engine to operating temp attempting to adjust. The throttle appears to be at 700-750rpm, I got a reading of about .335v @ closed throttle. Then, reconnected plug and restarted car and adjusted distributor. The car idles pretty close to what I stated above, with a hiccup here and there but quickly corrects itself. In drive(automatic car) with the brake on, rpm is at 500rpm. Has strong power, and no engine noise.
Any thoughts as to why I'm getting that reading on the TPS?
