SES/CEL Codes 5th Gen
Postby maxhopper » Sun Jul 17, 2005 5:17 pm
P0011 - IVT Control (Bank 1)
P0021 - IVT Control (Bank 2)
P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)
P0032 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 2)
P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1)
P0038 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 2)
P0051 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 2)
P0052 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 2)
P0057 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 1)
P0058 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 2)
P0100 - Mass Air Flow Sensor
P0101 - Mass Air Flow Sensor Circuit Range / Performance Problem
P0102 - Mass Air Flow Sensor Circuit Low Input
P0103 - Mass Air Flow Sensor Circuit High Input
P0105 - Absolute Pressure Sensor
P0107 - Absolute Pressure Sensor Circuit Low Input
P0108 - Absolute Pressure Sensor High Input
P0110 - Intake Air Temperature Sensor
P0112 - Intake Air Temperature Sensor Circuit Low Input
P0113 - Intake Air Temperature Sensor Circuit High Input
P0115 - Engine Coolant Temperature Sensor Circuit
P0117 - Engine Coolant Temperature Sensor Circuit Low Input
P0118 - Engine Coolant Temperature Sensor Circuit High Input
P0120 - Throttle Position Sensor
P0122 - Throttle Position Sensor 2 Circuit Low Input
P0123 - Throttle Position Sensor 2 Circuit High Input
P0125 - Insufficient Engine Coolant Temperature For Closed Loop Fuel Control
P0127 - Intake Air Temperature Too High
P0128 - Thermostat Malfunction
P0130 - Front O2 Sensor Circuit (Bank 1)
P0131 - Front O2 Sensor (Lean) (Bank 1)
P0132 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 1)
P0133 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 1)
P0134 - (2000-2001) Front O2 Sensor High Input (Bank 1)
P0134 - (2002-2003) Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 1)
P0135 - Front O2 Sensor Heater (Bank 1)
P0137 - Rear O2 Sensor Low Input (Bank 1)
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
P0140 - Rear O2 Sensor High Input (Bank 1)
P0141 - Rear O2 Sensor Heater (Bank 1)
P0150 - Front O2 Sensor Circuit (Bank 2)
P0151 - Front O2 Sensor (Lean) (Bank 2)
P0152 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 2)
P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
P0154 - (2000-2001) Front O2 Sensor High Input (Bank 2)
P0154 - (2002-2003) Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 2)
P0155 - Front O2 Sensor Heater (Bank 2)
P0157 - Rear O2 Sensor Low Input (Bank 2)
P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)
P0159 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 2)
P0160 - Rear O2 Sensor High Input (Bank 2)
P0161 - Rear O2 Sensor Heater (Bank 2)
P0171 - Fuel Injection System Too Lean (Bank 1)
P0172 - Fuel Injection System Too Rich (Bank 1)
P0174 - Fuel Injection System Too Lean (Bank 2)
P0175 - Fuel Injection System Too Rich (Bank 2)
P0180 - Fuel Tank Temperature Sensor
P0181 - Fuel Tank Temperature Sensor Circuit Range / Performance
P0182 - Fuel Tank Temperature Sensor Low Input
P0183 - Fuel Tank Temperature Sensor High Input
P0217 - Coolant Over Temperature Enrichment Protection
P0221 - Throttle Position Sensor Circuit Range / Performance Problem
P0222 - Throttle Position Sensor 1 Circuit Low Input
P0223 - Throttle Position Sensor 1 Circuit High Input
P0226 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
P0227 - Accelerator Pedal Position Sensor 1 Circuit Low Input
P0228 - Accelerator Pedal Position Sensor 1 Circuit High Input
P0300 - Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfired Detected
P0302 - Cylinder 2 Misfired Detected
P0303 - Cylinder 3 Misfired Detected
P0304 - Cylinder 4 Misfired Detected
P0305 - Cylinder 5 Misfired Detected
P0306 - Cylinder 6 Misfired Detected
P0325 - Knock Sensor
P0327 - Knock Sensor Circuit Low Input
P0328 - Knock Sensor Circuit High Input
P0335 - Crankshaft Position Sensor Circuit
P0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)
P0345 - Camshaft Position Sensor (Phase) Circuit (Bank 2)
P0400 - EGR Function (Close)
P0403 - EGR Volume Control Valve Circuit
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
P0440 - EVAP Control System Small Leak
P0441 - EVAP Control System Incorrect Purge Flow
P0442 - EVAP Control System Small Leak Detected (Negative Pressure)
P0443 - EVAP Canister Purge Volume Control Solenoid Valve Circuit
P0444 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Open
P0445 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Shorted
P0446 - EVAP Canister Vent Control Valve Circuit
P0447 - EVAP Canister Vent Control Valve Circuit Open
P0450 - EVAP Control System Pressure Sensor
P0452 - EVAP Control System Pressure Sensor Low Input
P0453 - EVAP Control System Pressure Sensor High Input
P0455 - EVAP Control System Gross Leak
P0456 - EVAP Emission Control System Very Small Leak (Negative Pressure Check)
P0460 - Fuel Level Sensor Circuit Noise
P0461 - Fuel Level Sensor Circuit Range / Performance
P0462 - Fuel Level Sensor Circuit Low Input
P0463 - Fuel Level Sensor Circuit High Input
P0464 - Fuel Level Sensor Circuit
P0500 - Vehicle Speed Sensor
P0505 - Idle Air Control Valve / Auxiliary Air Control Valve
P0506 - Idle Speed Control System RPM Lower Than Expected
P0507 - Idle Speed Control System RPM Higher Than Expected
P0510 - Closed Throttle Position Switch
P0550 - Power Steering Pressure Sensor Circuit
P0600 - A/T Communication Line
P0605 - Engine Control Module (ECM)
P0650 - Malfunction Indicator (MIL) Control Circuit
P1065 - ECM Power Supply Circuit
P1102 - Mass Air Flow Sensor Circuit Range / Performance Problem
P1121 - Electric Throttle Control Actuator
P1121 - ABS / TCS Control Unit Performance
P1122 - Electric Throttle Control Performance Problem
P1124 - Throttle Control Motor Relay Circuit Short
P1126 - (2000-2001) Thermostat Function
P1126 - (2002-2003) Throttle Control Motor Relay Circuit Open
P1128 - Throttle Control Motor Relay Circuit Short
P1130 - Swirl Control Valve Control Solenoid Valve
P1143 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 1)
P1144 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 1)
P1146 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 1)
P1147 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 1)
P1148 - Closed Loop Control (Bank 1)
P1163 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 2)
P1164 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 2)
P1165 - Swirl Control Valve Control Vacuum Check Switch
P1166 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 2)
P1167 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 2)
P1168 - Closed Loop Control (Bank 2)
P1211 - ABS/TCS Control Unit
P1212 - ABS / TCS Communication Line
P1217 - Engine Over Temperature
P1223 - Throttle Position Sensor 2 Circuit Low Input
P1224 - Throttle Position Sensor 2 Circuit High Input
P1225 - Closed Throttle Position Learning Performance Problem
P1226 - Closed Throttle Position Learning Performance Problem
P1227 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P1228 - Accelerator Pedal Position Sensor 2 Circuit High Input
P1229 - Sensor Power Supply Circuit Short
P1320 - Ignition Signal
P1335 - Crankshaft Position Sensor (REF)
P1336 - Crankshaft Position Sensor (POS) (COG)
P1401 - EGR Temperature Sensor
P1402 - EGR Function (Open)
P1440 - EVAP Control System Small Leak
P1444 - EVAP Canister Purge Volume Control Solenoid Valve
P1446 - EVAP Canister Vent Control Valve Closed
P1447 - EVAP Emission Control System Purge Flow Monitoring
P1448 - EVAP Canister Vent Control Valve Open
P1456 - EVAP Emission Control System Very Small Leak (Positive Pressure Check)
P1464 - Fuel Level Sensor Circuit Ground Signal
P1490 - Vacuum Cut Valve Bypass Valve Circuit
P1491 - Vacuum Cut Valve Bypass Valve Circuit
P1564 - Automatic Speed Control Device Steering Switch
P1572 - Automatic Speed Control Device Brake Switch
P1574 - Automatic Speed Control Device Vehicle Speed Sensor
P1605 - A/T Diagnosis Communication Line
P1706 - Park / Neutral Position Switch
P1800 - VIAS Control Solenoid Valve Circuit Open
P1805 - Brake Switch
P2122 - Accelerator Pedal Position Sensor 1 Circuit Low Input
P2123 - Accelerator Pedal Position Sensor 1 Circuit High Input
P2127 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P2128 - Accelerator Pedal Position Sensor 2 Circuit High Input
P2135 - Throttle Position Sensor Circuit Range / Performance Problem
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
U1000 - CAN Communication Line
U1001 - CAN Communication Line
Linked to How-to/Info Sticky.
maxhopper
Car: 02 Maxima SE 6spd
Return to Maxima Forum & I30 / I35 Forum
