Ryan Heo »
https://forums.nicoclub.com/ryan-heo-u67107.html
Fri Jul 06, 2007 7:21 pm
Hi.I used a bottle( not 1/2 bottle) of seafoam by vacuum line as a vidio where it was posted on NICO a month ago. It is still hard to start I think the reason is that the engine oil was changed immediately after I use the seafoam.
So I plan to do one more seafoam. This time I will buy two bottle of seafoam to use through a vacuum line( a half bottle), add engine oil(a half bottle), and put gas tank( a bottle). Is it ok? and Do I have to drive about 500 miles before chage new engine oil?
And I read the article on the Internet. Can I do that for my car?"Remove intake bellows from throttle body and push up out of the way. Have someone (or something) press the gas pedal all the way down, or manually move the throttle cable assembly under the hood, until the throttle blades are fully open. Spray Sea Foam Deep Creep into throttle body, fully soaking the blades, the bottom, top, and up and down into the intake manifold behind the throttle body. Use a good amount. "
When I change engine oil on this time, I would like to add Lucas stuffs which is good for engines and transmissions I heard from the auto store guy. However I couldn't find the review to use lucas on NICO. Would you tell me about Lucas stuff, if you guys have an experience? Thanks.
Modified by Ryan Heo at 11:16 PM 7/6/2007
