Original came out OK but when I was pressing in the new one it went about a quarter inch beyond the face. Fearing major problems, I decided to try and get the little SOB out.
That didn't go very well. After several hours of trying to pick and prod it out I was able to get a hold on the spring and ripped it out (if you're curious, that spring is about 3 feet long when uncoiled). During this process I managed to put a couple of nicks in the crank.
Is this likely to cause problems significant enough to merit replacing the crank? I'm at a stand-still currently until I get some advice on how to proceed. I don't mind a little oil leak now and then, but if it's going to be a major issue I'd like to know now before I put everything back together.
Thanks!
