Virgin Spec:
1996 Nissan 240SX SE – KA24DE, circa August 2002, found on a CarMax lot; untouched/unmolested and bone stock … Aw, just look at her.
Plans:
Retain overall stock body look, beef-up suspension and stance (or should I say down?), full-blown custom turbo the 2.4 liter KA. No thought whatsoever about swapping the KA for the SR. Goal = Fun street car and awesome 1320 ride!
Original Build List:
(** = updated/changed since original build; see updates way down below) Oh, and my deepest apologies if this doesn’t match up to the almighty JDM expectation ...
- KA24DE valve cover, polished
- KA24DE head race port/polish and gasket matched and cryo-treated
- JWT cams (.390L/275D)
- JWT adjustable cam sprockets
- Chrome-silicone dual valve springs w/ titanium retainers & custom seat locators
- REV Stainless steel valves (oversized intakes)
- ARP Head studs
- Cometic HP multi-layer metal head gasket **
- KA24DE engine block honed, blueprint & balance (crank, pistons, rods, flywheel & pressure plate)
- CP pistons (8.5:1)
- Wiseco piston rings
- Pauter forged rods
- Top Line rod and main bearings
- ARP Main studs
- Oil pressure regulator shimmed
- Oil pan modified for return and temperature gauge
- GReddy T67 compressor w/Mitsubishi 25G turbine
- Blitz blow-off valve (cold side)
- HKS blow-off valve (hot side)
- HKS race waste-gate
- Custom intercooler piping silver ceramic coated
- Custom down-pipe and extension, high-temp black ceramic coated
- Custom equal length exhaust manifold, high-temp black ceramic coated
- Custom large FMIC w/modified end-tanks
- Koyo aluminum radiator
- Flex-a-lite dual 12" electric fans **
- KA24DE OEM intake manifold ported & polished
- K&N cone filter
- GReddy oil catch can
- MSD ignition w/modified distributer **
- GReddy eManage piggyback ECU **
- Custom fuel rail
- High-pressure SS braided fuel lines
- Custom fuel injectors
- 300ZX turbo fuel pump
- Aeromotive fuel filter
- SX fuel pressure regulator w/FP gauge
- ACT Xtreme pressure plate
- JUN chromoly flywheel (modified for step height)
- Custom 4 puck ceramic "double-sprung" hub clutch disc
- Infiniti J30 VLSD
- APEXi GT Spec stainless steel cat-back (95mm (3.74 inch) mandrel bent w/115mm tip)
- SafeCraft 10lb Halon on-board fire extinguishing system
- RCI transmission blanket **
- Lakewood driveshaft loop
- Taylor aluminum battery box
- Optima redtop battery
- Tein HA coilover system (16 way adjustable damp)
- Tein pillow ball upper mounts
- Tein adjustable camber plates (front)
- Whiteline rear sub-frame suspension bushings
- Whiteline front and rear control arm bushings
- Cusco OS front strut tower bar
- Goodridge stainless steel brake lines
- OZ Racing Futura Modular 17x8 three piece wheels (front) **
- OZ Racing Futura Modular 17x10 three piece wheels (rear) **
- Ventura tires, 235/40R17 (front)
- Marshall Power Racer II tires 275/35R17 (rear) **
- Custom fiberglass eyelids
- Kouki side skirts
- Kouki tail lamp assembly
- Stripped decklid badging
- Cut out crosshair in center of front bumper cover
- Autometer Phantom boost gage **
- Autometer Phantom air/fuel ratio gage **
- Autometer Phantom exhaust temp gage
- Autometer Phantom oil temp gage
- Autometer Phantom oil pressure gage
- Autometer dual A-pillar pod
- Custom 3 pod gauge bezel below head unit **
- HKS Turbo Timer II **
- APEXi AVC-R boost controller **
- B&M T-shift knob **
- MOMO Millennium steering wheel
- MOMO Grand Prix pedals
- MOMO real leather shift boot
- Katzkin leather interior w/matching door inserts; dark graphite w/pearl centers
The Pics:
- ARP Head studs
- ARP Main studs
- K&N cone filter
- Custom fuel rail
- Infiniti J30 VLSD
- Taylor aluminum battery box **
- OZ Racing Futura Modular 17x8 rims (front) **
- OZ Racing Futura Modular 17x10 rims (rear) **
- Kouki side skirts
Updated/changed items since original build:
- Cometic HP multi-layer metal head gasket – Also o-ringed block
- Flex-a-lite dual 12" electric fans – Motors went bad; went back to OEM clutch-fan set-up
- MSD ignition w/modified distributer – Axed in favor of stand-alone management; covered distributer hole with XS Engineering plate
- GReddy eManage piggyback ECU – Replaced w/ EMS 8860 stand-alone engine management system
- RCI transmission blanket – Actually never installed; still new on my shelf (I’ll get to it)
- OZ Racing Futura Modular 17x8 rims (front) – Replace w/ Rays Engineering Volk Racing GT-7 17x8
- OZ Racing Futura Modular 17x10 rims (rear) – Replace w/ Rays Engineering Volk Racing GT-7 18x10
- Marshall Power Racer II tires 275/35R17 (rear) – Replaced w/ BFGoodrich g-Force drag radials 275/35R18
- B&M T-shift knob – Replaced with Momo
- Custom 3 pod gauge bezel below head unit – Removed exhaust temp; relocated to ashtray location
- HKS Turbo Timer II – Replaced with GReddy full auto turbo timer
- APEXi AVC-R boost controller – Replaced with GReddy PRofec Type-S boost controller
