Look at the pictures and you'll see why it was so cheap...
Look at all that rust and bondo and I don't even know what else
Air vents for the added 5 horsepower
It had a rear end collision and the PO used a lot of bondo to fix it...
Gonna make a sticker that says "Insert Rust Here"
No leaks through the T-Tops, which I'm pretty impressed about, I actually let it outside and it poured all day today. went to check any leaks, and none...
Analog gauges, Everything works
Boost gauge moves but it doesn't get passed 0...
Had like 10 pounds of carpet all stashed in the back and rotting away, so I just threw it out... Weight reduction Stage .5
And the anticipated engine bay shot
I need a new battery
T- T- T- Turbo
So there it is, not much of a looker, but it does the job fine...
Pros:
It's a manual (Still learning)
Electronics surprisingly work, the electronic lumbar support still works, windows work, side view mirrors work, all lights work, radio works, and the AC blows but not cold
Rear wheel drive, I drive a 2013 Base Corolla Auto, not very fun
Nissan, I like Nissan and want to work on them in the future, so I thought this would be a good starting point
T- T- T- Turrrbo Vg30, that has some work to be done
Cons:
The freggin' body looks like Frankenstein's monster
I don't know how deep the rust runs
Engine runs, but it's hesitant and loud
Fuel sender unit must be bad or leaking injector cause I'm getting like 5 mpg
A friend and I believe the u-joints are bad
Starter doesn't work
Smells dusty
Speakers suck
I believe back right suspension is collapsed
Hasn't been registered since 2002
and some other things
I'm a student for Auto Tech so I'll have a look at it on Wednesday when we have shop days and I work at Ford as a Lube Tech so I'll be doing coolant flush, oil change, diff fluid, brake fluid, and check for any other mishaps...
For now it's just sitting in the driveway waiting to get registered and get a new starter put in...
Future plans: (Please guys, tell me recommendations because I'm not so fluent in 80's Nissans as I'm more of a Subaru fanboy, but Subarus are hard to find here)
New Starter Motor
Registration
New Battery (I would like to relocate it as well to the back)
Rims and tyres (My friend wants the current rims and I'm not a fan of them anyways)
U-Joints
Get suspension sorted (Cheapo coilovers are my idea)
Clean out intake and throttle plate
Some Seafoam
Check how bad the rust is holding back performance
Replace Timing Belt, Spark Plugs, fuel pump and injectors
I believe there's a misfire too so I gotta check that out.
And then from there on just some sanding down the body, cutting out the rust spots and rivetting some metal plates, then a rattle can paintjob
And that's it for now
I'd also like to meet with anybody in the area to tell more in person about this car, I never liked this model, but recently I've had a fetish for them...
- Steve
