hyearm »
https://forums.nicoclub.com/hyearm-u227181.html
Tue Nov 05, 2013 6:38 pm
Hi,
new to forum,just got my 2011 G37 Coupe IPL and need new tires.
Factory size tires are Front 225/45/19 and rear 245/40/19
I was wondering what is the downside if I install 245/40/19 tires both front and rear?
Any adjustments to alignment/suspension/controls needed if I use wider tire in front.
Tire shop said that wider tire fits in front where rim which is 8.5", and rear rim is 9" wide
Based on simple calculations if I use 245/40/19 in front instead of 225/45/195, tire will be sitting about 3mm lower, i.e. effective front wheel diameter will decrease by 6mm ( 225*0.45=101.25mm and 245*0.4=98mm)
Thanks for any insights
hyearm
