rxm6 »
https://forums.nicoclub.com/rxm6-u60513.html
Wed Jul 29, 2009 5:38 am
So my driver door is sagging and in order for it to be aligned with the rear door you have to lift it slightly. So, i'm getting hinges, easy solution.
But, another problem I have is that when the door is shut, it actually sinks in farther than the rear door, creating a lip where the rear door begins. This creates a whistle at 40+ speeds and it upsets me when I look in the rear view mirror. I looked at all the components and the striker and the latch appear to have normal wear, with no excessive gouging or anything like that. Just curious if any of you guys have ever experienced this or know whats causing it? The hinges will help with the sagging door, but could they also be the cause of the mis-alignment? Seems like it would be something to do with the striker and latch?
