loystock wrote:Please check level and color of ATF. A good fluid is pinkish red in color. If it is faded or brownish, I suggest you do a flush as soon as you can. ATF deteriorates due to heat and as it ages over time.
I agree with this. Perhaps look into installing an in-line transmission filter such as a
Magnefine to filter the transmission fluid. The Magnefine contains filtering media (similar to that found in a typical oil filter) which has efficiency in the vicinity of 35 microns, as well as a powerful magnet very similar to the one found in the transmission pan to trap all ferrous wear material, as well as improve efficiency of the filter somewhat since size is not a restriction for the magnet. A 3/8" one will most likely fit the current transmission cooler return line hose.
Any Infiniti dealer will be able to print out the entire service history of your vehicle (obviously that only applies for service done at dealerships). Also, you can do a transmission cooler line exchange yourself if you would like to save some cash and if the weather permits. Here are the steps:
You will need:
12 to 15 quarts of automatic transmission fluid, preferably Nissan Matic D
A clear gallon jug, something like an empty milk jug
Another large container to store used fluid for disposal
1. Disconnect the transmission cooler return line and secure it in a collection bucket such as a clear gallon milk jug. This will be the hose on the driver side of the vehicle; disconnect the end leading towards the transmission.
2. Have a helper start the car while you watch the bucket - once it's half full (2 quarts), yell for the helper to stop the engine.
3. Add 2 quarts of ATF through the transmission dipstick.
4. Drain collection jug into larger jug (i.e. a Disposoil - these only hold 10 quarts though in my experience, so have something else to hold the last 5 quarts).
5. Repeat steps 2-4 until you're out of ATF.
6. Check fluid for proper level (see the next question and answer for details), and recycle the old ATF. Any place that takes used oil will likely recycle ATF.
