So I have a second hand SAFC 2 I have a few mods on the engine so I just want to be able to do some tweeking on it if need be and well I dont have the instructions for it and I have searched here and google and theres alot of confusing stuff out there so I am going to run by what I have and see if anyone on here has installed one and make sure this is correct.
SAFC2 WIRES:
Red= Power and goes to pin59 ( on my ECU Pinout may not be right 12V switched ECCS.)
Brown= ground closest to ECU
Black = ground atleast 1 CM away from brown but on same ground pin 60? next to IG power?
Green= RPM is pin 7
grey= Throttle and goes to pin 38
White= Air flow on loom side goes to pin 27?
Yellow= Air flow on ECU side goes to pin 27 as well?
The knock sensors I do not think I will be hooking up as they are pretty much useless. But that is a Purple wire.
What are the other wires for?
Is this the correct wiring?
http://wiki.r31skylineclub.com/images/t ... inouts.jpg
That is the pinout I was looking at but printing it out obscures the numbers up top lol.
ANY HELP WOULD BE GREAT!!! Thanks in advance.
