That's it mostly, but one more significant thing. You'll need either special bolts or a sleeve for each bolt to get the ring gear onto the hlsd unit. I mean your ring gear threaded hole is like a 12 mm and the diff hole is like a 13 mm. I have this setup and you need the bolts (someone says to torque it down and I don't recommend that at all). Here's another thread talking about it:
s15-diff-bolts-t212966.html
The bolts are kind of expensive, but they add a MM to the bolt diameter. Here's a place to buy them (ask for NICO Club discount of like 10%):
https://frsport.com/Nismo-38102-RS500-O ... 83185.html
The other option is to go to the parts store, get a foot or so of metal tube with 12mm inside diameter and 13mm outside diameter, go home and cut that into short sections just a hair thinner than the depth of the hole in the differential, then put those into each diff hole and run the 12mm bolts through those. The sleeves are what I did for my car... fit like a glove.
Now, the hard stuff... you may need a huge splitter to remove old bearings and do need an equally huge press to install the new ones. Consider finding a local shop and paying a few bucks to have them do it for you. I paid $15. Setting backlash requires a variety of shims to select the correct thickness from to align your gear mesh. Google it to see procedures in write ups and videos. Check out preload as well. Also, check the FSM, I'm pretty sure the procedure is in there in addition to the specs for measuring the lash and lap type stuff. The real issue here is that if your backlash doesn't just work on the first try, then you'll need different shims and they're expensive, especially if you think you need a variety to choose from. So, I took mine into a 4x4 offroad shop (they practically specialize in differentials) and had them shim it for me to set backlash and preload. This cost me $80 and I feel I overpaid a bit. Now, you could be lucky and your current shims might work (plus you can swap sides for a different fitment) and you just need some marker stuff to check the gear mesh.
