s14 Wheel wire tuck
Nonsense
Car: s14 zenki
So im getting ready to put coilovers on my car and decided to tuck the wire a bit higher. This is what i came up with.The only thing im worried about is the wire is still under a little bit at the end.I tried everything and couldn't get it on the top.
samxini
Car: '95 240sx w/Kouki conversion
I've seen some people build a little plate out of sheet metal and bend it to cover that area, then just weld/bolt it in place.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Do as suggested or get some thick wire loom for that part.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
samxini wrote:I've seen some people build a little plate out of sheet metal and bend it to cover that area, then just weld/bolt it in place.
Youre talking about mine? If not where else have you seen it?
Nonsense
Car: s14 zenki
I dont think i would be able to weld anything (No tools or know how lol) so i think im going to buy a thick rubber hose, wrap it around the wire and hope for the best
lancet913
Car: 1996 240sx se
KA24DET @12psi
What side view mirrors are on your car?
Nonsense
Car: s14 zenki
Stock? I got the car like that.
el_cognito
Car: s14 98 kouki
Nonsense wrote:I dont think i would be able to weld anything (No tools or know how lol) so i think im going to buy a thick rubber hose, wrap it around the wire and hope for the best
I've also seen other people just cut about an inch where the harness is closest to the fenderwell, and there should be enough space to bend it inwards so the harness can be movable upward.
just google: wire tuck s14
Nonsense
Car: s14 zenki
^ Ill probably do that then i wouldnt want my Harness to get hacked up
duffman1278
If you really wanted to though you could also cut and reroute the wires, but then you'd have to solder them and I don't know if you're up for that.
wanganss13
Car: 1991 s13, 1996 celica, 2004 x-type
duffman1278 wrote:If you really wanted to though you could also cut and reroute the wires, but then you'd have to solder them and I don't know if you're up for that.
I agree. I think thats your best choice. That way you dont have to cut off any parts of the car, plus its easy.
AZ89two4Tsx
Here's fine.
E7-S14
Car: ess 14 foo!
with the 19smine rubbed on that one spot after i tucked it up in the fender.
i just wrapped into some rubber hose and watched it.
spooled240
Car: kouki s14
cutting the wires and extending the harness would probably be the BEST way without welding or hacking up the fender well...i should've done that
Krew126
Car: 1993 240sx Coupe
I'm actually gonna have to do this on my S13 when I lower it another .5 inch to an inch. Is the best way to do it to take a big a** hammer to the seam that rubs on the tires and bend it outward, and then just pull the harness a little and ziptie so it'll be above the wheel well?
