the s14 motor use 370cc injectors instead of 480cc so you would need a set of 370cc or get a tune for 480cc injectors.808datsun510 wrote:hey guys thanks alot for your help. If i do run an s14 harness and coil packs with the s15 engine will i have to run an s14 computer also or can i use my s15 ecu? or does it even matter? some ying yang before me did a nice hack attack job and i figure it would jus be easier to replace the whole harness than rip my hair out trying to solder heat shrink and try replace all the broken connectors
Oh yea thats one thing I forgot. I have a set of 370cc out of that same s14 engine if you are interested also.david200095367 wrote:
Oh ok, I was not sure. I was talking to a shop while trying to figure out which motor I had.garagelu wrote:No you are wrong about the valve covers. S14 and S15 valve covers are the same. I know for sure you can put s14 coil packs in a s15 engine. My friend has a s15 motorset in his shop and I test fitted a s14 coil pack in there.
He searched for months for a s15 engine harness and had to get a friend of his in japan to mail one to him. I think it took a month or two. He didn't know you could use s14 stuff.
Yes, I just skipped the ignitor all together.808datsun510 wrote:thanks guys for the help i have a set of s15 spitfire coil packs and would really like to keep them, so falco basically did you just by pass the ignitor?
